Surface to surface contact ansys apdl
I need help on creating rigid to flexible surf to surf contact using contact pair wizard in ansys apdl. the selection of rigid to flexible mode is due to different stiffness of two different material. for rigid as target, this part should not be meshed before proceed with contact wizard. however, when i finished the contact wizrad, do i need to mesh the target solid before solveing?
thanks for any help.
