Array of Points - CATIA
I'd like to create an array of points, including their associated properties: x, y, z, (etc.), using VB. I am working on a script to create a Point class, and add the properties in as member variables of a Point object. Is this possible in VB?
Has anyone done something like this before? I have also considered creating an array of hybridshape objects, but I'm not sure if I can collect all of the information I'd like from each point.
RE: Array of Points - CATIA
In my last script I was about to create a new class for point when I changed my mind and used the Type function instead (just like in FAQ560-1824: VERY Useful Catia VBA Functions) ... I had points in collections. I use collection so I can do for each x in y...
I am not VB expert but I think you can have your own object from your own class in an array.
Eric N.
