Journal function don't do what documentation say.
Hi
This is a revised journal (journal from this forum)
I added these 2 lines
Dim File,Window As ListingWindow.DeviceType
lw.SelectDevice(File, "C:\vita_vme_std\Export\cloning_log.txt")
but the cloning log don't go to the file
instead it still go to the information window.
Can someone give a clue, what wrong.
Thanks in advanced.
Thanks in advanced.
CODE -->
'Here is a basic code snippet that will add the current displayed assembly to
'the clone process, apply a naming rule (in this case adding "-"
'to the end of every component), and define the output folder:
Option Strict Off
Imports System
Imports System.Windows.Forms
Imports NXOpen
Imports NXOpen.Assemblies
Imports NXOpenUI
Imports NXOpenUI.FormUtilities
Imports NXOpen.UF
Module Module1
Public Sub Main()
Dim theSession As Session = Session.GetSession()
Dim theUISession As UI = UI.GetUI
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim theUFS As NXOpen.UF.UFSession = NXOpen.UF.UFSession.GetUFSession()
Dim lw As ListingWindow = theSession.ListingWindow
Dim Current_Assembly As String = displayPart.FullPath
Dim cloner As NXOpen.UF.UFClone = theUFS.Clone
cloner.Terminate()
cloner.Initialise(NXOpen.UF.UFClone.OperationClass.CloneOperation)
cloner.SetDefNaming(UFClone.NamingTechnique.NamingRule)
cloner.SetDefDirectory("C:\vita_vme_std\Export\\Export")
cloner.AddAssembly(Current_Assembly, Nothing)
Dim opt As NXOpen.UF.UFClone.ExLogOpts
opt.allow_missing_components = False
Dim namerule1 As NXOpen.UF.UFClone.NameRuleDef
namerule1.type = UFClone.NameRuleType.AppendString
namerule1.new_string = "-"
cloner.SetNameRule(namerule1, Nothing)
cloner.SetDryrun(False)
cloner.PerformClone(Nothing)
cloner.Terminate()
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image when the NX session terminates
GetUnloadOption = NXOpen.Session.LibraryUnloadOption.AtTermination
End Function
End Module
RE: Journal function don't do what documentation say.
CODE
'use listing window to write to file and window lw.SelectDevice(ListingWindow.DeviceType.FileAndWindow, outputFile) lw.Open() 'write information to listing window lw.WriteLine("full path: " & workPart.FullPath) lw.WriteLine(New String("-", ("full path: " & workPart.FullPath).Length)) lw.WriteLine("file name: " & fileName) lw.WriteLine("file name w/o extension: " & fileNameNoExt) lw.WriteLine("parent folder: " & parentFolder) lw.WriteLine("root folder: " & root) lw.WriteLine("") lw.Close() 'flush file buffer by changing listing window device lw.SelectDevice(ListingWindow.DeviceType.Window, "")You can find the above code and some more explanation in the article here.
www.nxjournaling.com
lw.open() and the flush command
to my journal will amended the journal.
to my journal will repairs the journal.
Also note that some operations (such as cloning) may ignore your settings and do what they want. Below are a couple of threads from the Siemens programming forum:
https://community.plm.automation.siemens.com/t5/NX...
Maybe I need to live with those pop up cloning reports.
