Premature Exit of week long running code
I have written a code to pull data from an excel spread sheet which is being continuously updated by a program called WinDaq. The data is load cell data and the intent is to let this run for a week and pull data every twenty minutes.
For some reason after 13 hours the code just stopped. The computer did updates last night, but that was at 3 am and the code stopped prematurely at 8 pm. I have a save showing that the WinDaq software continued to pull data at least another 20 minutes.
I'd post my code, but it worked well for 13 hours and I don't think that the problem is there. I suspect there is an error handler or something in 2003 to prevent code from continuing excessively and I am not accounting for that.
Has anyone run into this issue before. Here is a quick run down on the code logic
Privat bStop As Boolean 'determines when stop button has been pressed
while not bStop
Do the data collection
For counter 1 to 120
' Dump the buffer every 10 seconds for 20 minutes to maintain connection to WinDaq and register button cancellation
Next counter
Save the file 'The reason I have data 20 minutes after that last data collection
Loop
Thanks in advance for any help
RE: Premature Exit of week long running code
Plz post your code. The devil is in the details.
Skip,
glassesJust traded in my OLD subtlety...
for a NUance!tongue
The code is relatively simple as follows:
' Used to stop the program when button is pushed
Private bStop As Boolean
Sub CollectData()
' test Macro
' Macro recorded 11/8/2017 by teeyanaw
Dim loadA_Colm As String
Dim loadB_Colm As String
Dim load_Row As Integer
Dim loadA_Cell As String
Dim loadB_Cell As String
Dim pasteCell As String
Dim newHour As Integer
Dim newMinute As Integer
Dim newSecond As Integer
Dim counter As Integer
Dim loadValue As Double
loadA_Cell = "K10"
loadB_Cell = "K15"
load_Row = 2
loadA_Colm = "A"
loadB_Colm = "B"
bStop = False
' So long as the stop button has not been pressed continue with loop
Do While Not bStop
'counter = 1
' Open sheet 1 and select the cells containing the average load value set above
Sheets("Sheet1").Select
'Range(loadA_Cell).Select
' Set Cell Value as a long value for loadValue
loadValue = Worksheets("Sheet1").Range(loadA_Cell).Value
' Goto Sheet two
Sheets("Sheet2").Select
' Pastecell contains the cell location to put the data, changes everytime
pasteCell = loadA_Colm + CStr(load_Row)
' Select the pastecell location and set the value equal to the loadValue variable
Range(pasteCell).Select
ActiveCell.Value = loadValue
loadValue = Worksheets("Sheet1").Range(loadB_Cell).Value
' Goto Sheet two
pasteCell = loadB_Colm + CStr(load_Row)
'Insert Timestamp
Range("C" + CStr(load_Row)).Select
ActiveCell.Value = Format(Now, "mm/dd/yyyy HH:mm:ss")
' Move row counter down one row
load_Row = load_Row + 1
' Goto Sheet one to wait out
' Intended to allow buffer to clear multiple times while waiting for the next entry
' currently set to clear buffer every 10 seconds and pull data every 20 min
For counter = 1 To 120
' Wait ten seconds between buffer clearing
newHour = Hour(Now())
newMinute = Minute(Now())
newSecond = Second(Now()) + 10
waitTime = TimeSerial(newHour, newMinute, newSecond)
Application.Wait waitTime
'DoEvents will clear the buffer and deposit the DAQ data, maintaining the connection
DoEvents
If bStop = True Then counter = 120
Next counter
' Save File
ActiveWorkbook.Save
' For debug limits how many times program will run
' If load_Row = 6 Then Exit Sub
Loop
End Sub
Sub StopIt()
bStop = True
End Sub
I have found in research since posting that the save function should be clearing the memory removing the possibility that the premature exit is due to an excel memory issue from the windaq add-on.
Also last night it ran all night with no issue and is still running now. Which puts the run time at 26 hours so far.
As for event logs I am unsure how to find one for Excel when no error appears to have been triggered. Advice for where to go on that would be appreciated. It is a windows 7 system currently running Excel 2003.
1) Your DoEvents belongs inside the 10 second wait. DoEvents enables the user to hit the STOP button among other Excel things.
2) Exits from loops should be accomplished without changing the counter according to best practices.
CODE
            Do
                DoEvents
                If waitTime >= Now() Then Exit Do
            Loop
            If bStop Then Exit For
        Next counter
Skip,
for a NUance!tongue
Took me a bit to figure out why you coded it that way, but I like what I think that would do. It doesn't solve how everything will run fine for 13 or so hours and stop, but it would definitely make everything run nice and smooth. I could posibbly remove the counter and just go straight to the 20 minutes.
Thank you for the coding advice.
Do you think that 10 second lag could be causing the issue with the program stopping for no reason?
Just noticed, waitTime starts out 10 seconds greater than Now() so
CODE
    If waitTime <= Now() Then Exit Do
Nothing wrong with a delay, 10 sec or 20 min.
Skip,
for a NUance!tongue
Tight loops sometimes benefit from Sleep(1) after Doevents.
Instead of using Timeserial. Add 10 seconds to Now().
WaitTime = Now() + (10/86400)
