Dear All, its pleasure to join eng
Dear All,
its pleasure to join eng-tip forums..
i have inquiry .
i have chiller panel soft starter 700 KW 415 v. and Im facing problem with cable termination,the hole of cable lugs are bigger than the hole of bus bar and bolt size , but when we use washer its look ok and tighten firmly and no loss , so does the gap between bolt and the dia of bolt will effect .
Kindly note this problem is in the out going cables , each cable will carry (I/sqrt(3))..
Thanks and best regards
i have inquiry .
RE: Dear All, its pleasure to join eng
