Metal stud lengths
Metal stud lengths
I am working on the design of a theater building. The building will be steel construction with concrete over metal floors and roof. The exterior walls will be non-bearing metal studs with cement plaster finish. The lateral system will be braced frames set inside the exterior walls.
At one area, the walls are 40' tall with a 4' parapet. I will be using wf columns and horiz wind girts to reduce the span of the studs. My questions are:
1) Can you get studs 44' in length?
2) Is this a good or bad idea to use a single stud?
3) Alternatively, I can break the studs at the wind girts with a track top and bottom. Is this better than full height studs?
Thanks for any advice.
RE: Metal stud lengths
Just make sure that if you do so you're not relying on the continuity and you design them as simple spam from girt to girt.
Dik
Thanks for the help!
