Drainage profile - How to determine vertical scale?
I kinda feel stupid asking this question, but I can't get my head around it.
I just finished displaying a drainage pipe profile exaggerated 10 times on the vertical. No exaggeration on the Horizontal, so thats 1:1.
If my vertical is exaggerated 10 times, and I have a 20-scale border sheet around it. When I print full size, what would the vertical scale be? I need to indicate this on the print sheet.
I know the horizontal scale is 1"=20', but what would be the vertical scale?
Any help would be appreciated.
Thanks.
Thanks.
RE: Drainage profile - How to determine vertical scale?
The vert. scale would be 1" = 2', along with the horiz. scale of 1" = 20', that’s a ratio of 10/1.
Thanks for the input. Trying to do the math on this, whats the rule of thumb?
I am guessing you take the border sheet scale and divide by the vertical exaggeration amount to get the scale. So in this scale 20-scale border sheet / 10-vertical exaggeration = 2 .
Dik
I don’t know exactly what a “border sheet” is, or what “a 20-scale border sheet around it.” really means. I suppose I have seen what you are talking about, but I’m not really understanding your terminology or what you are trying to do. I don’t know that there is some magic rule of thumb for this, but you can draw the two axes at any scale you want. Obviously, scales with nice round numbers are convenient 2, 5, 10, etc. You are changing these scales to be able to truly and fairly/honestly show the plotted variations. If you have a very flat profile with a max. variation of 1 or 2' in 100', you can hardly see those changes on a drawing/graph, so you exaggerate the vert. scale to show the relative changes at a glance, or to allow interpolation btwn. points. You said “my vertical is exaggerated 10 times,” and “the horizontal scale is 1"=20'.” So, my math was your 1" = 20' horiz. scale, or 20'/10 = 2', thus 1" = 2' on the vert. scale, that is, 1" on the vert. axis should equal one10th (.1) as much stuff as 1" represents on the horiz. scale. Maybe another way of saying it is that it takes 10" on the vert. axis to show the same amount of stuff as 1" does on the horiz. axis. An exaggeration of 5 times would be, 20'/5 = 4', thus 1" = 4' scale on the vert. axis. Maybe some good Surveying, Highway Design, or Engineering Graphics and Drawing text books would shed some light on this topic. Interestingly, you would do just the opposite scale jockeying if you were shooting elevations in the mountains and drawing the profile of a line.
I guess my intent was to put a vertical scale on the sheet so that when printed, a reviewer can easily determine the vertical scale. The "border sheet" is reference to a boundary around the drawing that determines the scale of the drawing, say for a full size is 22" x 34" and its 20 scale on the horizontal. This is civil (Transportation) terminology.
I think @dhengr gets what I am trying to get at. Thanks for the explanation (@ dhengr )
use graphic for both horizontal and vertical
