Create Chart with multiple collections definde by cells
I am trying to create a chart with many plots and would like to do something similar to the code below.
Sub Macro1()
Dim R1, R2, R3, R4, R5, R6, R7 As Range
Dim RR(11) As Range
Sheet2.Select
For i = 0 To 11
Set RR(i) = Range(Cells(9, 2 + 9 * i), Cells(209, 2 + 9 * i))
Next i
Range(RR(0),RR(1),RR(2),RR(3),RR(4),RR(5),RR(6),RR(7),RR(8),RR(9),RR(10),RR(11)).Select
ActiveSheet.Shapes.AddChart2(240, xlXYScatterLinesNoMarkers).Select
ActiveChart.SetSourceData Source:=Range(RR(0),RR(1),RR(2))
ActiveChart.SeriesCollection.NewSeries
ActiveChart.FullSeriesCollection(1).Name = CELLS(8,2)
ActiveChart.FullSeriesCollection(1).XValues = RR(0)
ActiveChart.FullSeriesCollection(1).Values =RR(1)
FOR I=2 TO 11
ActiveChart.FullSeriesCollection(I).Name = CELLS(8,2 + 9 * i)
ActiveChart.FullSeriesCollection(I).XValues = RR(0)
ActiveChart.FullSeriesCollection(I).Values =RR(I)
NEXT I
End Sub
Please advise
Thank you
Sub Macro1()
Dim RR(11) As Range
Sheet2.Select
For i = 0 To 11
Next i
FOR I=2 TO 11
NEXT I
End Sub
Please advise
Thank you
RE: Create Chart with multiple collections definde by cells
What problems are you experiencing with your code and/or with your chart result?
Plz upload representative sample source data with 12 columns of data.
Skip,
Just traded in my OLD subtlety...
for a NUance!
what I am trying to do is defining an ARRAY of ranges, so I can use the definitions of the series collections in a loop (using the cells method)
Skip,
for a NUance!
Now it fails on
ActiveChart.SetSourceData Source:=Range(RR(0), RR(1), RR(2))
I do not know how to proceed with the "Union"
What does that mean?
Skip,
for a NUance!
CODE
' Union(RR(0), RR(1), RR(2), RR(3), RR(4), RR(5), RR(6), RR(7), RR(8), RR(9), RR(10), RR(11)).Select ActiveSheet.Shapes.AddChart 240, xlXYScatterLinesNoMarkersIs that what you intended?
Skip,
for a NUance!
