text needed in FINITE DIFFERENCE METHOD
Hi all,
I'd be grateful if any body can recommend me any text (text book or so ever) for solving circular plates via FINITE DIFFERENCE METHOD ? specially if it would be supported with illustrative numerical examples...
RE: text needed in FINITE DIFFERENCE METHOD
there seemed to be lots of relevant hits.
H. Bruce Jackson
ElectroMechanical Product Development
UMD 1984
UCF 1993
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
https://welsim.com
Not really. FEA has no advantage over the FDM or FVM with curved geometry (unless FEA codes now have elements with curved edges. If that's the case then curved elements must be a VERY recent development).
CFD using FDM/FVM are better-suited for any problems with moving fluids, especially heat transfer problems with convection. FEA forces the user to make WAGs on convection coefficients which the user must apply surface-by-surface. WAG boundary conditions lead to WAG results! Junk In = Junk Out. CFD using FDM or FVM does not need convection boundary conditions since it solves the equations of fluid motion and heat transfer together.
I know of just one CFD code that uses FEA and that is CFDesign. I wasted weeks on that code trying to get solutions on meshes so unwieldy that the solution times were on the order of hours. I found it to be extremely difficult to keep mesh densities manageable and frankly couldn't get much done with it, even with CFDesign Tech Support.
H. Bruce Jackson
UMD 1984
UCF 1993
https://welsim.com
tunalover
