Bending schedule for curved beams and spiral stairs
Hello guys, graphically, how is bending schedule done for curved beams and spiral stairs as compared with straight beams and stairs which are very simple. Thanks.
RE: Bending schedule for curved beams and spiral stairs
also called Bar Schedule, PLEASE see the attached.
1. Design the columns, the stairway "legs" (the supports angling out from the (usual) central column and the individual stair treads, the stair treads themselves, and the column attachment points.
2. Design the needed rebar for each repeating element, trying very hard to keep every step identical from top to bottom.
3. From each step, draft the spiral reinforcement curves and bends. You most likely cannot use a "standard" schedule of simple 90 degree bends from a catalog or table.
Yes, the picture i attached was just to help make my question clear with respect to how curved bars schedule is done.i am much concern about curved bar schedule,for the steel/bar bender. thanks
