Material
Material
if a pipe and flange is of carbon steel, then orifice plate (to be installed in that pipe/flange) will be of carbon steel or any other material (Stainless steel etc) can be used ??
John120
John120
RE: Material
RE: Material
RE: Material
John120
RE: Material
If you are referring to galvanic corrosion between CS and SS, there is a very low corrosion potential between the two materials..... Virtually no corrosion between the two.
Additionally, the orifice gaskets tend to electrically isolate the two materials.
MJCronin
Sr. Process Engineer
RE: Material
The other way around, i.e. small C stl element in a Stl Stl one where galvanic corrosion can occur can eat C Stl very quickly.
RE: Material
John120
RE: Material
RE: Material
You need something that will nearly zero corrosion and erosion in your media, at velocities much higher than the pipe sees.
RE: Material
Galvanic corrosion between the CS piping and SS orifice plate is negligible. However, carbon pick-up by the SS plate could be an issue. Always better to use a low carbon SS.
RE: Material
Following careful shearing, squares of sheets are machined/laser cut to circular discs. Other methods such as stamping or burning the plate blanks are relatively inaccurate. Plates are typically finished to 15-30 micro-inch roughness, applied by special sanding machines designed to preserve the flatness of each plate. Fabrication methods avoid procedures which may damage the bore accuracy or the plate finish.
