Heat load calculation for the control cabinets
I have to give inputs to HVAC engineer regarding heat loads in the control room.The control room contains the PLc cabinets and Lighting.How shall i calculate the heat loads for a PLc cabinet.The cabinet is having AB make PLC,isolation transformer,power supply and terminals.CAn anybody help me in calculating this.Thanks in advance.
RE: Heat load calculation for the control cabinets
