Catia properties box input
Hi Gents,
I have added some extra boxes to my part properties using a macro.
What I'm trying to do is prompt an input to populate some of the extra boxes.
I have the input boxes working ok but I can figure how to put the oLength from the input box into the strParam2.ValuateFromString ""
any ideas?
cheers
Alan
RE: Catia properties box input
There really isn't enough info here to be able to answer this.
It sounds like you want to set a parameter value based on what someone types into an input box.
It would be something like
Jump.ValuateFromString("50mm")
So you would need to add the "mm" onto the end if your user is only entering numbers.
Thanks lardman363
