Turbine and Compressor maps, where to find it?
Is there any online resource or database of turbines and compressor maps. Especialy I am interested in KKK and HOLSET manufectors.
RE: Turbine and Compressor maps, where to find it?
-=Whittey=-
http://www.sjmautotechnik.com/turbomap.htm
I did not know that situation is so bad!
If somebody hase in the catalogue "Holset H2D93 5 1 N/S28.B11" turbokompressor maps please scan it and send it on my mail zoransa@yahoo.com
I will buy you a beer.
generally, turbo manufacturers don't divulge that info (except to OEM's). I've never seen turbine maps- only compressor maps. The turbos are generally defined by a basic model no. and trim no. The trim generally defines things like compressor geometry and diffuser geometry.
here's Holset's UK website, it gives basic compressor mass flow numbers for their current product line. I don't know if that will help you or not.
http://www.holset.co.uk/flash/index.html
Terry
Drew
This site is an upgrade guide for the 3000GT twin turbo, and has compressor maps for a lot of Mitsubishi (MHI) turbos.
http://www.stealth316.com/2-turboguide.htm
OK if comebody has similar problem... I still did not find Holset performance maps.
