partlist templates
partlist templates
Hi All,
I had to reinstall NX11 after a crash. Now when I want to drag a partlist template into the drawing environment the assembly contrains dialog starts.
How can I change this behavior?
Attached a partlist template example.
Lars
NX11.0.2.7 native
Solid Edge
Inventor
RE: partlist templates
- This sounds as if you drag from the history palette.
If Yes, did you setup the parts list palette ".pax" and store it somewhere server?
Then open that directory in a windows explorer and double click the .pax file.
It will start a new NX session ( native) but your next session will have that palette added.
- You can also in the running NX session go Preferences - Palettes - Open palette, then browse/select the pax file. ( Same result)
Tomas
I don't have a Pax file.
Previously I used the preferences-->palettes-->open directory as palette (atleast I think this was a long time ago)
For making the pax file, can I just cope a pax file and change the input? Is there a standard pax file for part-lists
Kind regards,
Lars
Lars
NX11.0.2.7 native
Solid Edge
Inventor
same as in the other thread, it's controlled by a system variable UGII_TABLE_TEMPLATES ( in case you move your pax & templates from "D:\siemens\NX11.0\UGII\table_files" )
See example of .pax in D:\siemens\NX11.0\UGII\table_files
- It has a special type of classification, similar to this :
<ObjectData class="PartsListTemplate">
( side note: this palette is a bit inconsistent to the reuse library, but it works excellent.)
Tomas
Lars
NX11.0.2.7 native
Solid Edge
Inventor
