Material Identification
What does 384/80/19 stand for? I know 384 is aluminum, but i'm having trouble identifying the other two numbers. I'm using a Niton Analyzer and the material i'm shooting is A356. Is this the same as 384/80/19?
RE: Material Identification
A356 is for Steel Castings, Carbon, Low Alloy, and Stainless Steel, Heavy-Walled for Steam Turbines
In A356, grade 6 has a minimum of 80 ksi UTS and 18.0% elongation. Although those numbers match closely, grade 8 is a 1%C, 1%Mo, Va alloy. I dont htink it has anything to do aluminum.
A356 is indeed a variety of cast aluminum. ASTM A356 deals with cast steel.
