Abaqus parametric study on multiple CPU cores
I have a parametric study which is launched by .psf file. The problem is, I want it to run on all cores of my CPU. When i submit "classic" job via cmd, i just append "CPUs=8" and it works. But when I use command "abaqus script=xxx.psf", it does not have CPUs option.
I think, the key command which sets up job for analysis is .execute command, but it also has no option for number of CPUs. I could maybe generate and submit jobs in cycle by myself, but i can't load abaqus modules in .psf file (using abaqus script=xxx.psf).
Is there any way to run every job of parametric study on all cores of my CPU? Thank you very much in advance.
Ondrej
Ondrej
RE: Abaqus parametric study on multiple CPU cores
Abaqus 2016 Analysis User's Guide - 20.2.4 - aStudy.execute():
So, this would look like: aStudy.execute(token, execOptions='cpus=X')
