polyolefine foam tape material properties
Does anyone have test data and or other material properties to define a polyolefine foam tape? I am creating a finite element model using a (.6 - 1.1 mm thick) foam tape as the gasket between 2 aluminum housings which are bolted and compressed together. This analysis will use Abaqus.
RE: polyolefine foam tape material properties
Rick Fischer
Principal Engineer
Argonne National Laboratory
