Is ADAMS capable of simulating heat from friction
Dear Members,
Is it possible to model heat generated from friciton in Adams? If so, then how?
Thanks for any help!
RE: Is ADAMS capable of simulating heat from friction
Cheers
Greg Locock
Rubbish. More politely, a usersub can do anything you can think of. It takes inputs and supplies outputs. Joining the inputs to the outputs is 'just' programming. Marc may be a good way of doing the bit inbetween.Cheers
Greg Locock
