NX 11 - (Fixed) rack and pinion
I have some issues with the "rack and pinion"-function in NX 11.
So far I have only seen examples where the pinion is rotating and the rack is moving transversal.
In my configuration the rack is fixed and shouldn't move.
The pinion on the other hand should rotate and hence move along the rack.
Does anyone have an idea how I can achieve that?
Thanks and regards,
Christian
