Ansys invalid volume error in harmonic response analysis
Hi all
I am doing a structural and harmonic response analysis, I have a cylinder like part with some complications in geometry that's designed in Catia and imported in various formats like igs, step and parasolid, set up as b_spline in compatibility in Catia(which i set it after getting invalid volume error in static and modal analysis). But I still get the error in harmonic response analysis. Do you know the reason and the solution to this problem ?
