Vibrational loosening, steel bolt in aluminum threads
I have a lighting bracket which is cast of an aluminum. This has been tapped, the thickness is 3/8". The manufacturer uses a galvanized steel bolt. This bolt screws through the aluminum casting and engages a 2" steel pipe, thus holding the fixture in place (or so the theory goes).
The bolt fit is "sloppy", i.e. I dont think the tapping was done with the right lube. The manufacturer recommends 30 Ft-lbs. We break each casting at 30 ft-lbs. Then the manufacturer states use 20 ft-lbs. I don't think either 20 or 30 ft-lbs is enough preload to keep this 25 foot tall lighting pole connection from vibrating itself loose in short order.
Any help on analytic method to prove this point (prior to the now installed lights falling down) will be greatly appreciated.
Pacific Steve
Pacific Steve
RE: Vibrational loosening, steel bolt in aluminum threads
Flores
The aluminum casting is threaded to allow the bolts to act as set screws. On each casting (there are a few varieties) there are either 4 bolts or 2 bolts.
The Aluminum casting fails by brittle cracking that originates at the threads.
I would say there would be substantial tension and bending in the aluminum. The light fixtures are an array of 4 ea 8 foot long fluorescents -- they catch a lot of wind, and at 25' up the pole will defintitely have movement.
The bolts are 3/8-16. They look like zinc coated in some manner. The threads through the aluminum are quite sloppy, although I dont know of a good way to classify them as 1, 2, or 3 "fit". The aluminum thickness is about 3/8" or about the same as the bolt diameter.
Under these conditions, can someone show a method by which the minimum preload torque can be established?
Big thanks, this is a great forum. Lots of science in fastening, I just wish I knew it already.
A place to start is torque balance:
Tstrip = Tinput - Tfric
Tfric = 0.58 · d2 · μ · F
d2 is the thread pitch diameter
μ is friction coefficient
F is force
Standard joint calculations assume screw tension and joint compression. It seems your joint has the screw in compression, and I don't know how to calculate a force from this. One way might be:
δ = P · θ / 2 π
where
δ is displacement
P is thread pitch (1/16" here)
θ is rotation angle
But what stiffness, elastic modulus, and length should be used to convert displacement into force? I am stuck here.
The casting supports up to 140 lbs of lighting fixtures, which are cantilevered off to one side. The moment arm would be about 18" (guessing). The casting itself is light, under 2 pounds.
I can email pictures, provide you email address, indicate if you wish to receive digital picture in the 2.3M size, or I can convert to smaller.
Thanks!
Lcubed
Note the dash after pacific
If the aluminum is surrounding
the pipe and you have a differential
the aluminum ring would expand and thus
decrease or lessen the given preload.
I do agree that helicoils should be used
& I would increase the size to 3/8 inch
bolts. I also would prefer 3 or 5 so
they are not opposing each other.
How hard is the pipe? If any ice formed
between the pipe and aluminum,
it could expand and loosen the preload.
What kind of temperature extremes are the
parts seeing? Looking forward to other
comments and solutions. Hope no one got
hurt.
1) you could put springs under the bolt heads to maintain some tension on the bolts.
2) you could put a hose clamp aroung hte outside of the heads of the bolts to keep them from turning out.
3) you could drill holes in the inner pipe for the bolts to go through, and use a through bolt.
