Journal Update all drawings
Cowski,
I'd like to change the code beneath. So when I run the journal all drawing and drawing views are updated.
Can you tell mee how to do this?
ub Main (ByVal args() As String)
Dim theSession As NXOpen.Session = NXOpen.Session.GetSession()
Dim workPart As NXOpen.Part = theSession.Parts.Work
Dim displayPart As NXOpen.Part = theSession.Parts.Display
Dim markId1 As NXOpen.Session.UndoMarkId = Nothing
markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Update Views")
Dim views1(1) As NXOpen.Drawings.DraftingView
Dim projectedView1 As NXOpen.Drawings.ProjectedView = CType(workPart.DraftingViews.FindObject("ORTHO@2"), NXOpen.Drawings.ProjectedView)
views1(0) = projectedView1
Dim baseView1 As NXOpen.Drawings.BaseView = CType(workPart.DraftingViews.FindObject("Front@1"), NXOpen.Drawings.BaseView)
views1(1) = baseView1
workPart.DraftingViews.UpdateViews(views1)
' Menu: Edit->View->Update...
Dim markId2 As NXOpen.Session.UndoMarkId = Nothing
markId2 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Visible, "Start")
Dim updateViewsBuilder1 As NXOpen.Drawings.UpdateViewsBuilder = Nothing
updateViewsBuilder1 = workPart.DraftingViews.CreateUpdateViewsBuilder()
theSession.SetUndoMarkName(markId2, "Update Views Dialog")
updateViewsBuilder1.Destroy()
theSession.UndoToMark(markId2, Nothing)
theSession.DeleteUndoMark(markId2, Nothing)
Lars
NX11.0.2.7 native
Solid Edge
Inventor
RE: Journal Update all drawings
The .UpdateViews method has various options to update all the views, only the out of date views, or only the specified views. Check out the help file on .UpdateViews, it probably has an option that will work for your needs.
www.nxjournaling.com
ok thnx
Lars
NX11.0.2.7 native
Solid Edge
Inventor
Cowski,
Where can I find this file on UpdateViews?
Lars
Lars
NX11.0.2.7 native
Solid Edge
Inventor
