Warning message in NX CAM
Hi All,
I keep getting this information window warning message when I switch between modeling and manufacturing or when I start NX new and call up this part file. Anyone know how to stop or turn off this warning as there is NO problem with the toolpath and I have many of these blends programmed so there is a long list of these warnings every time.
Funny thing is the operation actually has three surfaces.
Message in information window:
Attribute in: FINISH_BLEND_1_1_1_2
Surface_Area_911
This operation has two surfaces forming a complete loop. It is possible for the material side or tool axis to be flipped when regenerating. Check this and adjust if necessary.
Rick D.
Win7 64 bit w/NX10.0.3.5 MP14 and NX11.0.1.11 MP1
Vericut 8.0
RE: Warning message in NX CAM
I am also receiving this message and my tool path has no problems. Did you figure out how to stop the information window warning from appearing?
Doug H.
