Deadline: "by the"
Deadline: "by the"
When a deadline is set as follows:
Document XXX is required by the 10th December.
Does that mean that I can provide the required document on the 10th December, say no later than 23h59 and be okay?
Or shall it be provided the day before.
I am not in position to send a query to the concerned party, in order to clarify any ambiguity.
I know this may be a classical question, please excuse this.
I am on a situation where I need to be play safe on this one...
RE: Deadline: "by the"
You can also send it on the first of December if you have it ready.
Sooner may be better. With later you could find out it got there TOO Late.
Sometimes its possible to do all the right things and still get bad results
So deliver before COB 9-December.
f-d
ípapß gordo ainÆt no madre flaca!
Thanks very much for your help.
It is just as easy to set a specific time, ie, "no later than 5pm on the 10th December"
Yes, this is a classical question. All above is correct. However, for larger contracts (for instance offshore North-Sea) it is often more precisely stated as 'in our hands (with given address) within December 10th'. Often time is added (within December 10th 10.00 pm).
We normally arrange to deliver by hand to get a written receipt, and also not before the given day to avoid possible pre-opening and misuse by leakage to competitors.
