API 6A RTJ 6B Groove with CRA overlay - Spectacle blind
thread794-422928: Weld Overlayed Dimension of RTJ groove in Standard Flanges
API 6A gives in Table 52 the rough machining detail. The depth to which material may be removed is 8 mm for a R39 4 1/16" class 5000 groove. This is the same as the raised face available on the flange.
I have a CS spectacle blind that needs to be overlayed with Inconel 625 weld overlay. The prescribed overlay thickness is 5 mm including the dilution thickness. The spectacle blind already has the min thickness at the groove bottom. If I am to machine this deeper to the 5 mm overlay depth needed. I suppose it would violate the above. Is there a consideration that the overlay thickness can be treated to contribute to the strength thickness.
RE: API 6A RTJ 6B Groove with CRA overlay - Spectacle blind
Hi svi,
Please review the ASME SA-265, Clause 7.0 and all the sub-clauses. The overlay may be included in the composite materials tensile strength.
Cheers,
gr2vessels
