Passive House - Apartment Building HVAC System
Would anyone happen to know what type of mechanical HVAC systems would be found in an apartment building required to meet passive housing standards? There is a lot of information on small size single residential passive house but not so much on medium and larger buildings. Thanks for the help.
RE: Passive House - Apartment Building HVAC System
Probably some air source heatpump for each unit to provide heating and cooling. Or a geothermal one if you have freezing temperatures.
Or condensing boiler (possibly with solar hot water) hydronic heat if you don't need AC.
Keith Cress
@DrRTU : Never thought of it like that good idea thanks, and would love to attend the event but Chicago is quiet far.
@willard3 : @itsmoked is correct depends on where you live. example: https://en.wikipedia.org/wiki/Passive_house
