Min_bend_radius in NX routing
Hi all -
I just want to know if any of you have succeeded in using the attribute MIN_BEND_RADIUS in PTB file used for stock (hose or a cable)....
In nx 11 doc, I can see that this should work in a NX routing- session...But it seems like NX doesn’t raise an errror if Bend Radius is exceeded...if the information about the minimum bendradius is defined in the PTB file...
Any comments would be nice....
Thanks in advance....
lklo
lklo
