Further reinforcement of weldolet
Hi, We have a scenario, where the stress exceeds at the 20"X10" weldolet. Is there any means to reinforce a weldolet, though weldolet itself is a integrally reinforced branch fitting.
RE: Further reinforcement of weldolet
If you need more reinforcement try bracing it or some other sort of support.
A different type of branch fitting might be better. Weldolet is a fixed type of reinforcement.
This project is a replacement of existing facility, where we have a constraint, that we have to go with the like to like replacement. But unfortunately stress analysis is been asked to done, and we find the stresses exceeds at many location, where we could managed at all except this one. In spite of our suggestion to change the branch connection type, we were insisted to go with the Weldolet. Now we are stuck up with excessive stress at the branch during the stress range and pure expansion case in ceasar. My stress engineer needs more reinforcement and I have no idea how to reinforce the Weldolet. The code is 31.3.
Dear Little inch,
I was out for a meeting, so couldn't respond immediately, sorry about it.
Dear Break Boy,
Could you share some drawing of RPAD for weldolets. I need it to illustrate.
Furthermore, you mention
This tells me you're talking about the thermal displacement stress range, thus secondary stresses
If one requires more reinforcement my first guess would the design doesnt meet B31.3 para 304.3.3, so the primary stress would most likely be the issue. Either you or your stress engineer didnt get it.
With all due respect but if you need pictures for such details you're not the right the person for this job.
Thanks for you remark, but I believe you didn't understand either the project requirement or my need. I have asked the picture for something I have never done and couldn't imagine of i.e. Rpad for weldolet. But please let me know if there is any possibility to strengthen the weldolet further with RPAD.
In this case you either need to reduce your stresses and forces by some other means, add a larger weldolet and then reduce down ( 12", 16" whatever), replace the weldolet with a branch and re-inforcement pad or pads ( which is all that a weldolet does, it just does it as a single element) or just accept the overstress on the basis that the existing pipework didn't break after ?? years service. If you're not changing anything, including the service conditions then you could argue that the stress analysis is just being conservative.
B31.3 gives the owner a large amount of leeway in terms of what they can accept.
Reinforcing a weldolet is not, IMHO, an option open to you as it would invalidate the acceptance of a weldolet as an integrally reinforced fitting and without going to an FEA model, I don't know how something like Caesar could actually accurately model it.
I suspect that this is some type of "unbalanced" system.... Some configuration that would not normally occur following normal and customary piping practices.
Could it be that a relatively large diameter piping branch is tied into a large diameter run pipe with an undersized weldolet ?
This would cause a perceived overstress at the weldolet by an inexperienced stress analyst.
Since the OP is so reluctant to tell us details of his situation, we may never know ...
MJCronin
Sr. Process Engineer
Sometimes the Stress Analysis goes off the rails when the Pipe Stress Engineer(PSE) uses the wrong Temperature in the evaluation.
There are normally four potential Temperatures for possible consideration:
- Design Temp
- High (product) Operating Temp
- Low (product) Operating Temp (Cryogenic)
- Environmental (High/Low) Temp.
Which temperature did your PSE use for these calcs?
Sometimes its possible to do all the right things and still get bad results
