3 degree statically indeterminate beam
Hello all,
I want to solve a 3 degree statically indeterminate beam (3 pins).The method that I need to follow is the force method + virtual method?
Is there any shorter way to calculate the reaction in that beam?
If you can plovide me any link or example it will be useful!
Thank you in advance!
RE: 3 degree statically indeterminate beam
You would be better off with a stiffness approach. Moment distribution, direct stiffness method, slope-deflection, etc.
