Cutting trouble
Cutting trouble
Hey guys only new really to laser cutting every thing has been going ok but today when cutting some 8mm plate I had this happening I don't know is it cut speed focus power hahahah has me a bit stumped
Thanks for any help
Matt
Thanks for any help
Matt
RE: Cutting trouble
With that image it seems a problem with unstable cutting (sometimes cuts clean other times just doesnt). This can happen because of your protective window or because of the laser centering. Did you check those?
Hope it helped.
"Nothing is true, everything is permitted."
RE: Cutting trouble
Thanks Matt
RE: Cutting trouble
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
RE: Cutting trouble
In my case (PRECITEC HEAD FIBER LASER) I have a protective window above 200mm of the nozzle, and sometimes, it gets points of "dirt" and it makes the cut unstable or it makes impossible to cut.
If it is possible I clean it, if not, I have to replace it for a new one.
Hope it helped,
RE: Cutting trouble
Yes I have been cutting along of 8mm and only a couple of times I have had this happen
But I just don't know why
Thanks Matt
RE: Cutting trouble
RE: Cutting trouble
Does this happen after a certain amount of cutting time? Or is it completely random?
What laser are you using?
RE: Cutting trouble
Look through the film with the lens in front of the monitor, stress will show up as rainbow colors.
You may have to rotate the film or your head for the best effect.
-AK2DM
"It's the questions that drive us"
RE: Cutting trouble
Amada sure is proud of their service. I'll leave it at that.
RE: Cutting trouble
RE: Cutting trouble
Would this be an issue for a service tech to address? Also, what size nozzle would you recommend for 1/2" HRS? A good set of cut conditions would be greatly appreciated.
RE: Cutting trouble
RE: Cutting trouble
