300 series stainless and urea.
We may be adding urea tanks into the engine rooms of our tug boats in the near future. While polyethylene is a great choice for in terms of chemical compatibility, I don't like the idea of using plastic tanks in a space that has a high fire potential. Are there any major corrosion issues using 304L or 316L stainless steels in a 30% aqueous solution of urea?
RE: 300 series stainless and urea.
However the risk of contamination is serious. A small amount of salt water in the tank would cause serious corrosion.
Perhaps you should look at using 2205. This is a duplex stainless and it is very strong, which allows for a much thinner tank.
This alloy would stand up much better if exposed to chlorides.
You could build a silo out of 3/16" 2205, that is way thicker than is needed.
Stiffness is a design issue, it isn't uncommon to see SS tanks built external stiffeners.
Might be worth a read.
http://be.linkedin.com/in/fusionpoint
