Relation between pipe velocity, pressure loss, pipe roughness
Don't you hate it when you have an excel calculation sheet, done by others, and there's no way for you to tell how the values were calculated?
Case in point, I have a calculation that uses VBA functions. I want to back engineer the calculations, so that I can validate the results. Unfortunately, the owner of the calculation locked the VBA developer, and I have no way to look at the code without a password.
So here's what I'm trying to figure out:
Function calculates the velocity in a pipe with certain diameter. Here's the thing: flow is not considered!
Here's a copy of the table, for thermoplastic pipe:
Size fps psid/100ft GPM
2 4.17 1.2 51.4
3 5.30 1.2 133
4 6.06 1.2 227
Size and pressure loss are input values. fps and GPM are calculated values.
When I look at the in-cell formula (function) for the velocity (fps), I can see the following parameters are used:
Pipe roughness
inside diameter
fluid density
dynamic viscosity
psid/100ft
max velocity (if calculated velocity is higher than max, then max velocity overrides result).
The flow GPM is then calculated based on the fps values, in effect giving us the capacity of the pipe.
So my question is, how can the velocity in a pipe, based on its diameter, be calculated, when the flow is not known, and using the parameters given?
I've looked inside Crane TP, Nayyar handbook, and several other sources. Also did a search in this forum. I must be missing something.
2 4.17 1.2 51.4
3 5.30 1.2 133
4 6.06 1.2 227
Pipe roughness
inside diameter
fluid density
dynamic viscosity
psid/100ft
I design aqueducts in a parallel universe.
RE: Relation between pipe velocity, pressure loss, pipe roughness
Katmar Software - AioFlo Pipe Hydraulics
http://katmarsoftware.com
"An undefined problem has an infinite number of solutions"
https://i.ytimg.com/vi/uM9nPHS7GSQ/maxresdefault.j...
If this spreadsheet was given to you for your use or review, than ask for an explanation of the calculation procedure. If you are pirating this spreadsheet, than you may have to generate your own code.
Fyi, I have this spreadsheet from a company I used to work for. Since I don't want to use it in my current firm, I'm just trying to figure out the engineering formulas behind the calcs. I'm not interested in the code itself as that would be proprietary. It's more of an intellectual exercise I'm keeping myself busy with during my downtime.
What I also hope to understand, eventually, is what this velocity means, compared to max or design velocity that is used everywhere to calculate the capacity of a pipe.
velocity is related to the available head and to the head losses through the pipe or channel.
these would include friction, elevation change, entrance and exit losses, momentum losses etc.
by the way mannings, chezy and Darcy Weisbach all can be used for pipes as well as open channels.
Step 1: calculate Reynolds # based on the given maximum velocity )(Equation 6-3)
Step 2: calculate friction factor using Colebrook equation 6-5
Step 3: Calculate the velocity in the pipe using Darcy equation 6-8 for delta_p
Voila.
I'm making an assumption they used maximum velocity to calculate the Reynolds # in Step 1. My manual calculation results are very similar to the function values. I'm guessing they used a function just to calculate the pesky Colebrook equation.
