Going back to a specific Abaqus simulation increment, and start all over again from that increment
Hello everyone,
I am working on a simulation in Abaqus, in which, I generate the boundary conditions using VUAMP user subroutine. The boundary conditions will be modified after each iteration of the Abaqus simulation. The modified BCs. for a specific iteration of the Abaqus simulation might not be the correct BCs. though. Here, I need to go back in Abaqus simulation to the previous iteration as if the last iteration has not happened, and modify the BCs. again and restart from the previous iteration, with the new BCs. Is there anyway that I can go back to a previous iteration in Abaqus, and just delete the last iteration? Then, I will apply the further modified BCs. and run the simulation again from that increment to get the right answer.
