Interface of interior non-load bearing and load bearing walls
I have a question about what is typically done at the interface of interior non-load bearing and load bearing cmu walls at the slab elevation. Should the thickened slab for the non-load bearing wall be poured directly on top of the load bearing footing, or should there be a layer of soil between the two? Please see the attached sketch for reference. Thanks!!!
RE: Interface of interior non-load bearing and load bearing walls
What happens if the strip footing settles? It would pull the slab on grade with it too I suppose, and a crack would develop in the cmu wall at a mortar joint somewhere? On the other hand, if there is a minimal thickness of soil between the bottom of the slab on grade and the top of the footing, that mass of soil would just drop with the strip footing, the slab would become unsupported at that location, and a crack would develop in the slab on grade. So if the strip footing does settle, I am left with either slabs cracks or cracks in mortar joints depending upon the detail I use? Does this logic make sense to everyone?
As far as your worries about settlement.....let me put it to you like this: you'd have a whole lot more settlement issues with that slab bearing on that short pocket of soil than from it sitting on the wall footing. I can promise you that pocket would not be compacted properly.
