Surface Roughness spec on a short length
I have a turned part which gets partially over molded with plastic. Only about 3 mm are inside the plastic. We spec a surface roughness of Ra 3.2 to 20 with a cut off length of 0.25 mm for this area because we want the plastic to tightly grip the part. Outside of the plastic the surface finish has to be quite smooth. The supplier greatly increases the tool feed rate where we want it to be rough with a single point tool, the part almost looks like it's threaded. The problem is the 0.25 mm cut off length filters out all the waviness and I get a surface finish reading of slightly less than 1.0. If the surface was longer I could use a 0.8 mm cut off length and the parts would pass but the region is too short for that. What kind of measurement can I use on a short surface that won't filter out the waviness? These parts are good, you can run your thumb nail over them and feel the roughness, just can't measure it.
RE: Surface Roughness spec on a short length
TTFN (ta ta for now)
There are some online calculators that help determine the speed/feed rates for producing a desired surface roughness profile by turning. Achieving the specific surface texture profile you require in the location where the plastic material will be over-molded may require more than just a change in feed rate. Possibly a secondary operation using a cutting tool with different geometry.
If you need more information on how to define a specific surface texture condition on your engineering documentation, take a look at ASME B46.1-2009 and ASME Y14.36-1996.
What I'm saying is don't control your finish with a surface finish symbol, control it as a threaded surface.
If you only have 3 or 4 peaks and valleys, I don't think it will be very practical to specify or measure this in terms of surface roughness.
I'd recommend actually showing ridges on the drawing, defined with dimensions, tolerances, and notes as appropriate. Without knowing more details, my first thought would be to tolerance the crest diameter, radial depth, and axial spacing. Some additional control of the form (such as slope) might be justified as well, and could make the axial spacing tolerance unnecessary.
To provide some manufacturing flexibility, it may be helpful to allow either a single-start helix or multiple circular ridges.
Calculators similar to this for machined surface roughness and cusp height are widely available.
pylfrm
Thanks for the tip on turning surface finish calculators.
John Acosta, GDTP Senior Level
Manufacturing Engineering Tech
