Coldform / Gypsum Shear Wall
I've got a storage unit project using coldform framing. The exterior walls will be a typical coldform shearwall with gauge steel siding. However, the interior walls which I rely upon for shear, will only have 5/8" gyp board on both sides and no steel siding.
Do I need to use and R value of 2 instead of an R value of 6.5 ?! If so I'll need to put steel siding in all the interior walls. I'm hoping there's a way around this.
RE: Coldform / Gypsum Shear Wall
What do you use for the flat straps? CS/CMST coiled straps? I'm wondering about holes in the straps because Fu*An must be greater than Fy*Ag
You would have to check the strap for reduced area from the holes, but in my experience, the ability to get enough fasteners in the strap was the limiting factor.
