Journal Quastion on this statement ==> Dim sparts As Part() = s.Parts.ToArray()
Hi
I have a journal that grab assembly parts by the following statement
CODE -->
and do somthing with the parts. but I found that the parts array
contains parts from other assembly part in the session.
and I want only parts from the assembly part that the journal itself open
and manipulate.
How I can do that.
I'm using nx 8.5
and run this journal on NX Manger platform.
Thanks in advanced.
RE: Journal Quastion on this statement ==> Dim sparts As Part() = s.Parts.ToArray()
I assume that your "s" variable is a reference to the NX Session; if so, the session.parts array holds all the parts currently open in the session regardless of what assembly they belong to (if any). One way to get the parts in a particular assembly is to get the root component of the assembly and use its .GetChildren method to find the first level components of the assembly. If you need to get all the components in the assembly (components of sub-assemblies), you can use recursion to process all the components in the assembly. An example of this can be found here.
www.nxjournaling.com
Thank you Cowski
That's a brief and good explained example.
I browsed the code and I don't see
why it will not work on nx manager.
When I'll be on accessible nx manager I'll try it.
Thank you.
I just tested on teamcenter (TC 10, NX 9) using a small assembly and it worked without error.
Thank you a lot.
If you have SNAP, then you don't need the recursive code to find children of children of children, ....
You just get the root component, and use its Descendents property. This property has internal logic that does all the recursion for you.
There are lots of examples of this sort of thing in the Assemblies chapter of the "Getting Started with SNAP" document.
BubbaK Thank you your notice. (I have not a SNAP)
I found this GTAC journal with non-recursive sub for getting all components.
and I wonder witch one is more fastest the recursive one or the non-recursive one
CODE -->
'Date:  5-JUN-2008
'Subject:  Sample NX Open .NET Visual Basic program : rename components to part number
'Note:  GTAC provides programming examples for illustration only, and
'assumes that you are familiar with the programming language being
'demonstrated and the tools used to create and debug procedures.  GTAC
'support professionals can help explain the functionality of a particular
'procedure, but we will not modify these examples to provide added
'functionality or construct procedures to meet your specific needs.
' this should rename components in the current displayed part
' to the NXManager Part Number.
' Note that they will ONLY be renamed in the displayed part.
' So if part C is a component of part B and B is a component
' in part A, and A is the displayed part, component C will be
' renamed in A.  If you make B the displayed part, then
' component C will not appear to be renamed in that context.
Option Strict Off
Imports System
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Imports NXOpen.Utilities
Module rename_components_to_part_number
   Public s As Session = Session.GetSession()
   Public ufs As UFSession = UFSession.GetUFSession()
   Public lw As ListingWindow = s.ListingWindow
   Sub Main()
      Dim is_active As Boolean = False
      ufs.UF.IsUgmanagerActive(is_active)
      If is_active = False Then
         MsgBox("This program should be used in an NXManager environment.", _
                                                      MsgBoxStyle.Exclamation)
         Return
      End If
      Dim dp As Integer = 0
      dp = check_for_missing_display_part()
      If dp = 1 Then
         Return
      End If
      Dim dispPart As Part = s.Parts.Display
      Dim thisComp As NXOpen.Tag = NXOpen.Tag.Null
      Do
         thisComp = ask_next_component(dispPart.Tag, thisComp)
         If thisComp <> NXOpen.Tag.Null Then
            Dim partName As String = ""
            Dim refsetName As String = ""
            Dim instanceName As String = ""
            Dim origin(2) As Double
            Dim csysMatrix(8) As Double
            Dim transform(3, 3) As Double
            ufs.Assem.AskComponentData(thisComp, partName, refsetName, _
                             instanceName, origin, csysMatrix, transform)
            Dim partNumber As String = ""
            partNumber = ask_component_part_number(partName, thisComp)
            Dim thisInstance As NXOpen.Tag = _
                                ufs.Assem.AskInstOfPartOcc(thisComp)
            ' this changes what shows up in Component Properties->General->Name
            ufs.Obj.SetName(thisComp, partNumber)
            ' uncomment the following line to change the instance name
            'ufs.Assem.RenameInstance(thisInstance, partNumber)
         End If
      Loop Until thisComp = NXOpen.Tag.Null
   End Sub
   Public Function ask_component_part_number(ByVal partName As String, _
                                    ByVal comp As NXOpen.Tag) As String
      Dim partRev As String = ""
      Dim partFileType As String = ""
      Dim partFileName As String = ""
      ufs.Ugmgr.DecodePartFileName(partName, partNumber, _
                                   partRev, partFileType, partFileName)
      Return partNumber
   End Function
   Public Function ask_next_component(ByVal dispPartTag As NXOpen.Tag, _
                              ByVal comp As NXOpen.Tag) As NXOpen.Tag
      Dim type As Integer = 0
      Dim subtype As Integer = 0
      Do
         ufs.Obj.CycleObjsInPart(dispPartTag, _
                                 UFConstants.UF_component_type, comp)
         If NXOpen.Tag.Null = comp Then
            Return comp
         End If
         ufs.Obj.AskTypeAndSubtype(comp, type, subtype)
         If subtype = UFConstants.UF_part_occurrence_subtype Then
            Return comp
         End If
      Loop Until comp = NXOpen.Tag.Null
      Return comp
   End Function
   Public Function check_for_missing_display_part() As Integer
      Dim dispPart As Part = Nothing
      Try
         dispPart = s.Parts.Display
      Catch ex As Exception
         lw.Open()
         lw.WriteLine("+++Error: " & ex.ToString())
      End Try
      If dispPart Is Nothing Then
         lw.Open()
         lw.WriteLine("There is no current Displayed Part")
         ufs.UF.PrintSyslog("+++ERROR: There is no current Displayed Part", _
        False)
         Return 1
      End If
      Return 0
   End Function
   Public Function GetUnloadOption(ByVal dummy As String) As Integer
      Return Session.LibraryUnloadOption.Immediately
   End Function
End Module
