Stamping purpose
Stamping purpose
Stamping purpose
Hi Folks,
I just wanted to know the basic function of stamping a part in sheetmetal.Does it add the strength to the part? I know it is a simple question.But it would be great if you can guide a beginner.Awaiting your positive replies.
RE: Stamping purpose
It adds strength and if you're doing a lot of them it's the cheapest means of production.
Keith Cress
Thank you Keith.Any idea on how does it add strength to the part?
Whenever you bend a part you increase it's cross-section which makes it stiffer - considerably stiffer. Also, it work-hardens the metal by stretching it, that alone, also stiffens the part. Car bodies often have kinks and ridges stamped into them specifically to allow them to be made from thinner (less expensive) material.
Keith Cress
Wow! I never knew about this earlier.Thanks a ton keith.My knowledge on sheet metal has been stretched.
