How to determine support bearing surface length?
Hi there,
How would you go about calculating a suitable length for the bearing area of a slab, as shown in the diagram? For clarity the slab shown in the image is connected to a down-stand beam.
http://files.engineering.com/getfile.aspx?folder=9...
RE: How to determine support bearing surface length?
Not sure what you mean by slab is "connected" to a down-stand beam?
