unusual callout
unusual callout
Does anyone know what this callout means ?
Link
Any references to where it's defined will be appreciate it.
Thank you.
Link
Thank you.
RE: unusual callout
Those things on the right appear to be orientation plane indicators, defined in ISO 1101. They seem to serve a purpose similar to ASME Y14.5 bidirectional positional tolerancing.
I'm far from an expert on the ISO side of things, so you probably shouldn't consider this a definitive answer.
pylfrm
RE: unusual callout
Thanks a lot for the information!!
I searched, and I found more info related to these ISO symbols.
Thank you again.
RE: unusual callout
John Acosta, GDTP Senior Level
Manufacturing Engineering Tech
RE: unusual callout
In absence of Diameter indicator this is, most likely, bi-directional position tolerance.
So, one direction across the river and the other parallel
RE: unusual callout
RE: unusual callout
