ASTM A532 Class III Type A magnetic properties , for MP NDT
This is one of the wear resistant cast irons with very high chrome content, 23-28%.
It has been "suggested" that it is not ferromagnetic, or at least not enough to be successfully magnetized for Mag particle NDT.
But the otherwise quite thorough The "Abrasion-resistant cast iron handbook" talks generally about magnetic particle inspection, but says "No specialized adaptation of these techniques is required to examine alloyed AR cast irons."
- Does anyone know if this is the case ?
RE: ASTM A532 Class III Type A magnetic properties , for MP NDT
"Even,if you are a minority of one, truth is the truth."
Mahatma Gandhi.
