Coating temperature limits
Can anyone give general guidance on coating temperature limits, and the operating temperature buffer limits of equipment to give? Are there any general guidelines / best practices out there that say something like select coating with at least 10% higher max temperature rating than operating temperature limit? Thanks.
RE: Coating temperature limits
There is no such guidelines for coating selection followed in the industry. I have worked with Clients who requires coating to meet the design temperature. In my personal opinion, 10% than the max OT is quite sufficient and decent selection.
Coco- NACE PCS
Contractors & Suppliers may find a temperature ratings on a data sheet and not really understand what the result implies. Likewise, the dilatants & plasticizers in a coating may not be stable at "continuous" elevated temperature and migrate out of the coating causing embrittlement, crazing or crack/shrink. Some coatings, (epoxies) might undergo a post cure phase that is beneficial. Some coatings will soften to a state of toughness, while others might easily be damaged by otherwise mild (typical) physical abuse. An elevated temperature could change the water absorption rate.
There are manufactures with R&D who confidently write such letters, companies that are too buried in bureaucracy to write these letters and companies that won't because they don't know (Compounders w/o R&D). There may be some exceptional companies to too buried in bureaucracy to write these letters but if they are, then if later a claim is generated, they will also handle it a a glacial pace.
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
