Questions about helicoil screw assembly strength
Attached file is an excerpts from HELI-COIL tensile strength of threaded insert assembly.
The parent material is Al6061, and bolt strength is 420MPa, in this case, its intersection is below the 1 dia insert length.
• If I use 1 Dia insert, what’s the strength of assembly?
• If I use 1.5 Dia insert, what’s the strength of assembly?
RE: Questions about helicoil screw assembly strength
The point of that chart is not to tell you what the assembly strength is.
Do you have reference book recommend, or formula I can learn?
TTFN (ta ta for now)
How about the case that intersection is above the dia. line?
The fastener should always fail first.
The strength of the joint is the strength of the fastener.
