Analyzing and exporting results from a large number of load steps
I am working on an analysis which requires data from >100 load steps. I understand how to do everything in a single step with the GUI/commands, but not iteratively.
I am trying to do the following:
-Define the load steps
-Analyze with each load step
-Export certain results from each load step (into Excel or Matlab)
Conceptually, this is a straightforward operation, but I haven't yet figured out how to do it in the MAPDL through a for/do loop
Any help would be appreciated
Thanks in advance
Will
Thanks in advance
Will
RE: Analyzing and exporting results from a large number of load steps
There are a few ways to solve it described here: https://www.sharcnet.ca/Software/Ansys/17.0/en-us/help/ans_bas/Hlp_G_BAS3_10.html. My personal preference is Multiple Solve Method.
See the help files for the following commands for exporting results: SET, *CFOPEN, *GET or *VGET, *VWRITE and *CFCLOS.
Good luck,
Jason
/solu
*do,ls,1,100
time,ls
f,,,,,
d,,,,,
etc.
solve
*enddo
/post1
*do,ls,1,100
set,ls
*dim,data,,,,,,
*vfill,data(1,1),ramp,1,1
*vget,data(1,2),node,1,s,eqv
*vget,data(1,3),node,1,u,x
etc.
*cfopen,stress%ls%,dat
*vwrite,data(1,1),data(1,2)
fortran format statement
*cfclose
*cfopen,defl%ls%,dat
*vwrite,data(1,1),data(1,3)
*cfclose
*enddo
The *cfopens will create files named stress1.dat,stress2.dat, defl1.dat, etc. You can just as easily put them in one file if you prefer.
Rick Fischer
Principal Engineer
Argonne National Laboratory
Both replies have helped a bunch.
However, I'm still hung up on applying loads. I want to apply a pressure function on a set of nodes, and haven't gotten it to work through commands, only the gui. My approach is sf, [array of nodes], pres, [pressure function] but this fails at the array. The nodes are valid/have valid geometry. The documentation suggests a P51x, but I haven't figured out what that means.
Thanks again,
Will
Kind regards,
Jason
