SAP2000 Material Properties of Wood
I am modelling a wood truss in SAP2000, these are the material properties I used for wood:
Local Axis 1: Longtiudinal
Local Axis 2: Radial
Local Axis 3: Tangential
Define > Materials
Check 'Show Advanced Properties'
>Add New Material...>Material Type 'Other'>Material Name "SPF No.1/2"
Directional Symmetry Type: Orthotropic
>Modify/Show Material Properties
E1=E2=E3=9500 MPa (T5.3.1A CWC-Wood Design Manual)=6500e6 N/m^2 (if your units are set to (N, M, C)
For Axially Loaded Members as in a Wood Truss:
Poisson Ratios:
U12: Longitudinal Force causing Radial deformation = 0.280 to 0.422
U13: Longitudinal Force causing Tangential deformation = 0.292 to 0.462
U23: Radial Force causing Tangential deformation = 0.382 to 0.437
From [1] Green, Winandy, Kretschman, Chapter 4: Mechanical Properties of Wood (Not available in CWC-WDM)
From Canadian Wood Council - Wood Design Manual:
A1=4e-6 per C
A2=40e-6 per C
A3=27e-6 per C
Shear Modulus (Modulus of Rupture) from [1] and same convention as poisson ratio:
G12=0.078E to 0.131E
G13=0.053E to 0.138E
G23=0.003E to 0.017E
Weight per unit volume: 420 kg/m^3
Mass per unit volume: 4100 N/m^3
Nonlinear Material Data - Open for discussion
Material Damping Properties - Open for discussion
Thermal Properties - Open for discussion
Define > Materials
Poisson Ratios:
A1=4e-6 per C
A2=40e-6 per C
A3=27e-6 per C
My interests: Fire Safety Engineering, modern wood products, 3D Design and Drafting, Engineering Surveying
