concrete blinding dimensions
hello
for the concrete blinding dimensions under isolated footings, does it need to be same size of the footing or bigger. in our case we have a 30cm blinding since the hard rock is at 60cm below but the foundation top level is fixed. do i need to have the blinding size bigger than the foundation by 30cm (to follow the thickness)and is there anything in any code obliging me to do it.
RE: concrete blinding dimensions
MotorCity, blinding is just a working mat.
