Speeding up the consolidation process
Looking at ways to quicken up the consolidation process of a 20ha land overlain with very soft clay and sand layers with SPN less than 10.
Any novel ideas? I know the conventional way is adding surcharge and installing vertical drains. Any faster way?
RE: Speeding up the consolidation process
http://www.ad-hzm.co.jp/trr/hazama/2006/pdf_file/0...
Jam a piezo cone in the ground and see what you can clearly define.
Then I'd calculate the magnitude of consolidation and figure out what U% I'd need to mitigate the problem. Calculate the time for that U% and see whether you need a surcharge?
f-d
ípapß gordo ainÆt no madre flaca!
Good luck
Henry
f-d
f-d
