Standing Seam Disengagement
Hello all,
If we know that the seam of a 26 gauge (0.018'') thick standing seam panel disengages at 1,500 lbs, could we determine the load a 20 gauge (0.036'') standing seam panel would disengage? Assuming the properties are all the same and nothing else is the failure mode.
Thank you.
RE: Standing Seam Disengagement
No likely. The disengagement data comes from empirical testing, not calculations.
