Electric Planes. Why Not?
Article on Engineering.com
The article claims that electric powered aircraft will be much quieter than heat engine powered aircraft. Is this true? I was under the impression that what I hear from an aircraft flying overhead is the propeller or the rotor(s). Modern airliners are not muffled. They use high bypass turbo-fans, one of whose benefits is that they are quieter. Am I correct?
JHG
RE: Electric Planes. Why Not?
A 747 take off from LAX can be heard from at least 4 miles away, and there are airports where it's mandatory to do a full-power takeoff, which is particularly noisy.
TTFN (ta ta for now)
I anticipate that electric aircraft will be propeller driven. An alternate approach is a ducted fan, but either way, you are disturbing air.
JHG
I see the turbine hot section being replaced with an electric generator, the cold by-pass air going around the hot section with the compressor blades shrouded by the nacelle (sort of ducted).
I think most noise is coming from the hot section, that the by-pass compressor is shrouded by the nacelle.
I think that an electric generator replacing the hot section would be quieter.
I note the article didn't talk about how current electric aircraft have the same propulsion reliability as piston engine aircraft.
I think electric may allow multi engine configurations (once the reliability issues have been solved) running much smaller propellers and those propellers running with a lower tip speed which will have a large impact on noise. Something like the NASA X57.
Dik
and yes, if it's an open rotor (like a GA plane) probably most noise from the propeller, but not so for a jet with a high by-pass compressor shrouded by the nacelle.
I was thinking more about general aviation craft. One advantage of turbofans is they move more air at a lower velocity, which is what makes them quieter. If you were building an electric powered 747, would you use propellers or ducted fans? How much air would you have to disturb to get 350tonnes of aircraft off the ground? The process does not sound quiet.
JHG
> SAFETY -- turbo fans are fairly well shielded for catastrophic failures of the fans
> size -- to the first order, thrust is thrust, which requires a certain amount of air to be moved
> efficiency -- turbofans are more efficient than propellers or ducted fans at jet speeds
I think the basic lay-out of the airliner engine is close to optimal, so I think the electrical question is can you make an electric motor that'll output the same power as a current hot section and still be as small as the hot section (to fit within current engine profiles ? ... not to say that we have to use today's engines, but as a measure of proven efficiency ... if the generator is bigger, then the overall size will probably get bigger which will probably negatively impact efficiency.
The next electrical question is where is this power coming from ?
Well, that's easy; it's the Mr. Fusion that's sitting in the galley
B.E.
You are judged not by what you know, but by what you can do.
https://mdao.grc.nasa.gov/publications/AIAA-2012-3...
Seems like greedy financial sharks are looking to dupe nontechnical VC investors.
Cheers
Greg Locock
Pipistrel and the flight school are now trying to sort out the paperwork with the FAA , this actually may need a re write of a couple of regulations , since the FAA were not big on electric powered aircraft.
B.E.
Sure there may be applications where battery power/solar works, but it is not big biccies.
Cheers
Greg Locock
One of the speakers in this technical session covered the use of batteries for vehicle mobility - Cars, Marine, and Aerospace. Of course Cars are the big electric mobility player at the moment. In marine, he could only point to a tourist boat in Norway that was a diesel-electric hybrid as an example. In Aircraft - - - !!!! Nothing!. He briefly covered the possible combinations of battery-propulsion or hybrid engine-generator-battery-electric propulsion, but quickly pointed out that due to weight, and the energy density/weight of fuel over the energy density/weight of batteries the only possible practical combination was the Hybrid engine-generator-battery-electric propulsion with the battery deleted due to weight, and default to just a engine-generator-electric propulsion system! No one in the session made any statement challenging this, and the room was full of industry and academic power and battery experts!
I actually work in Wichita, the aircraft capital of the world, and Cessna did a one-off single propeller electric demonstrator about 9 years ago just to show the concept. The local aviation museum has a steam-engine that was used a 100 years ago to power a plane on a single flight. Frankly, at the moment, a battery power plane makes about as much sense as a steam-engine powered plane. Yes, you can make either technology power a plane, but there is no economic sense to it.
Obviously you can devote more payload to fuel, and I'd agree that an electric motor is lighter than that big lump of oily metal, but a factor of 6 is an enormous hurdle to overcome.
Cheers
Greg Locock
With the electric trainer ,
the 17 kWh battery pack was dual-redundant and designed to be either quickly replaceable within minutes or charged in less than one hour,
The cost of the recharge at this time is about $ 4.00
The Avgas for a similar sized trainer would be about $30.0 Depending where you live, it could be as high as $100.
B.E.
Cheers
Greg Locock
motors in aviation. I suppose in light aviation it will be like in the world of rc models: in the begining most modelists didn't trust to electric motors and batteries but nowadayas most of them use it. It's much more practical.
Of course this process will take much more time in real aviation. This video about big airplane with rc model components: https://www.youtube.com/watch?v=eNSN6qet1kE.
As for gas turbine it's really effective engines for aviation but large price restrain wide usage of them.The only hope is on modern technologies of manufactoring, for instance metal alloy 3D printing. It'll be able to decrease manufactoring expenses.
Cheers
Greg Locock
The advantages of electric, are lighter weight for the power unit , better control and no loss of power with altitude. Dis advantages limited power supply. However with a self launching sailplane this is a not a factor since it does not need much duration anyway. The newer lithium ion batteries are so much lighter these days, I recently received a 20 amp hour Li battery to replace a gel cell of the same size, when I got it, the battery was so light, I thought the shipper had forgotten to put the battery in the box, I rapidly opened the box and was relieved to find that in fact it was in there. As the battery science advances, the dis-advantages will become less and less. Remember there are crude solar powered aircraft out there now.
B.E.
Cheers
Greg Locock
That was done by Eric Raymond an acquaintance of mine, in a home built motor glider to prove the concept.
He also was responsible for some of the design work on Piccard's aircraft before they agreed to dis agree.
He is now making solar powered light aircraft.
B.E.
Cheers
Greg Locock
Well sure..., plus the pesky limitations of known Physics and present-day Chemistry.
Irrational extrapolation is much worse in all respects than essential skepticism. Such beliefs and opinions accomplish nothing except to distract and impede effective progress.
Such eco-campaigning can negatively impact sensible decision-making, and thus delay deployment of timely, cost-effective, and good-enough interim solutions. Thus such wishful thinking may actually increase the CO2 total Area Under The Curve.
Although a (solar-powered) electric airplane has circled the planet (taking about the same time as running), and a human-powered helicopter has lifted off (in a gym), campaigning for these sorts of things to be widely fielded now is a distraction and a diversion.
To be clear, little electric airplanes for basic flight training are already here. They do circuits for an hour, on $3 worth of power. Nice.
If battery technology ever reaches the point where it can power an airliner across the Pacific, then it'll have benefits far beyond merely powering an airliner across the Pacific.
Research into battery technology should be encouraged. Lobbying for its applications too early is not beneficial.
